Cow
- Eastern Oregon
- Electrician
I looked at a job that requires running a branch circuit 1000' through the ceilings of two different barns. The barns are typical metal buildings with z channels spaced 5' apart. The customer prefers pvc but with the spacing being as far apart as it is, it'd require me to use 1 1/4" pvc for this little 20 amp branch circuit. The load is very small so voltage drop is not an issue, the wire would still be #12 most likely.
That's where I thought 12-2 pvc coated mc cable might work for me since it can be strapped at 6' intervals. My worry is, how well do you think it would hold up in the ceiling of a barn, pigeons landing on it, building nests, etc? Would the birds claws tear the coating? I might be way off base even considering this since I've never used it, it just seems like it'd be a quick way to get a branch circuit across a long barn without resorting to running oversized pvc with expansion joints, etc.
Thanks for the help.
