Hello folks, newbie here.
I have an old Bryant B20-20FM panel. Here are salient facts about the installation:
1. The ground electrode comes from the street-side water pipe as a copper wire coming through a flexible metal conduit. This conduit attaches to the panel bottom wall and the copper wire comes through and terminates on a common neutral-ground bar.
2. The panel does not output any ground wires but only hot and neutral wires.
3. The neutral-ground bar does not appear to be bridged to the service panel enclosure, but I measure zero ohms between the bar and the enclosure.
4. Throughout the house ground conductors are derived from the metal conduit system. So the EGC path is intended to be the metal conduit system.
My question: Given the apparent lack of any visible connection of the neutral-ground bar to the panel enclosure, how does the metal conduit system/panel enclosure get connectivity with the neutral-ground bar? What is the typical/intended installtion to achieve that? Just trying to ensure everything is kosher in this old house and to understand things theoretically.
Thank you.
Thank you.
