Magic Gorge
- Lexington, KY
Given a generator set data sheet, I've often used this info from SKM as a quick reference for the necessary inputs: https://www.skm.com/Synchronous_Generator_Input_Data.html
However, sometimes the given stator resistance (0.0023 ohms in that example) is not quantified in the same way. In the attached screenshot, the line-line stator resistance values are shown. I believe the high wye connection most resembles the low impedance condition when susceptible to high faults, however is there more to consider for this "stator resistance" value?
