JFletcher
- Williamsburg, VA
I was looking for what is "standard" for screw wrapped terminals. Deciding to bypass the expertise of this forum for a moment (to conduct an experiment). I checked Google first, which lead me to youtube. If a picture is worth a thousand words, then a video must be gold, right? :happyno:
First up, "ExpertVillage". Surely by the name I'll get some "expert" tips here! Unfortunately, this two minute long video should be titled "How to Burn Down Your House"
There is absolutely nothing right about it. F-
Next up, "VideoJoeKnows". After 6 painful minutes, all I've learned is how to improperly connect the grounding wires together:
https://www.youtube.com/watch?v=2c6QaH4XBYE
F-
Still undaunted, I click on another video, this time by a "DIY" type guy. 3:30 minutes for a COMPLETE TUTORIAL on how to strip electrical wire! How can I go wrong? by watching it!:
https://www.youtube.com/watch?v=M_oMhBY-J_w
Inch to 1.5", tho our friend here is most likely confusing metric units of cm to in (that's an awfully short looking inch). Wrong tool: 'I need to strip wire, so I'll use this thing marked CUTTER'. Individual conductors are visibly crimped by his methods.
F
Well, I do have my inch to inch and a half strip length that I was looking for. Still, a bit uncomfortable, I figure I should get a second opinion:
https://www.youtube.com/watch?v=iM0tGSlUBwU
titled "Plug Wiring For Dummies - How To Wire A Home Electrical Plug Outlet". Whew, because I was feeling particularly stupid having watched the previous 3 videos. This video is 7:30 long, and in that time I learn:
~ How to cut NM cable with a pocketknife in a dangerous manner
~ How to strip NM cable with same pocketknife in a same dangerous manner
~ Highly dumbed down terms, like "stuff" and "thing"
~ Color codes (white to silver, black to gold) - dont need any more than that!
~ Strip gauge...too long, so cut em down to ???, like 3/8"...and wrap around screws with insulation under the screws to boot. Also learn how to ground a receptacle to a PVC box!
Would have given a C- for technical, but the improper ground method #1 safety issues drop the overall to an F.
So, seeing anywhere from ~3/8" strip length to 1.5", I figure I'll give one more video a go:
https://www.youtube.com/watch?v=UdkCiCqNz2g
6 minutes. 3/4" strip length. Clear, concise, technically correct. B.
(didnt know before I previewed the video limit per post was 1; only the first video is linked).
It's scary not only how much bad information is out there, but that people have taken the time to record and post it for others to see. Thankfully we have this forum, which, had I used from the get-go, would have had a battery of correct information posted in short order.
F-
F
