Valleybuilt
Please give me the code section that talks about how many devices can be on a branch circuit. My electrical contractor keeps using and billing me for a sub panel that I do not feel we need. Can some one help me?
charlie b said:This question is the subject of a long-standing disagreement in the industry, and in particular amongst members of this forum. To my knowledge, it is still not resolved. Some say it is unlimited, some say the limit is 10 (for a 20 amp circuit) and 8 (for a 15 amp circuit), and some say the answer is different for a dwelling unit as opposed to a commercial building. There is no article in the NEC that clearly gives an answer to this question.
Zip code 35601, from the OP's profile, corresponds to Decatur, AL.celtic said:Not knowing where the OP is located, hinders the process.
Valleybuilt said:Please give me the code section that talks about how many devices can be on a branch circuit. My electrical contractor keeps using and billing me for a sub panel that I do not feel we need. Can some one help me?
wbalsam1 said:Any nominal voltage outlets that are not included here are to be calculated at 180 volt-amperes per outlet. For 12 gage, 180 X 13 divided by 120 volts equals 19.5 amperes. I'd say no more than 13 outlets on circuits governed by 220.14(L).:smile:
iwire said:I can put 8763 receptacle outlets on a 15 or 20 amp dwelling unit circuit. :smile:
the maximum number of outlets permitted on 15- and 20-ampere branch circuits is 10 and 13 outlets, respectively. This restriction does not apply to outlets connected to general lighting or small-appliance branch circuits in dwelling units.
the maximum number of outlets permitted on 15- and 20-ampere branch circuits is 10 and 13 outlets, respectively. This restriction does not apply to outlets connected to general lighting or small-appliance branch circuits in dwelling units.roger said:Valleybuilt, the following is commentary from the National Electrical Code Handbook, notice the different requirements for residential.
[/color] [/color]
Roger
wbalsam1 said:Question for iwire: how many receptacle outlets not covered in 220.14(A)through(J) could you put in a dwelling?
charlie b said:Zip code 35601, from the OP's profile, corresponds to Decatur, AL.
tryinghard said:Check out 210.11
celtic said:In a dwelling unit....if I had a room that was 14' x 14' and I decided to put an outlet every 4" along the walls [only 1 door, no closets or anything else]...according to the NEC...how many circuits would be required?
..but we need them every 4" ~ does that mean I need a 20A CBtryinghard said:You can have one receptacle every 6" all on one 15A circuit.
celtic said:..but we need them every 4" ~ does that mean I need a 20A CB![]()
