sfav8r
- San Francisco Bay Area
We're on a job right now that just seems to be taking too long. I thought I would throw some numbers out there and see how long everyone else thought this job would take in man (people) hours.
It is a two story addition of approximately 2000 sq. ft. We are installing the following:
6 lighting outlets
27 duplex outlets
40 can lights
2 vent fans
11 single pole switches
6 3W switches
furnace (j-box)
There are 9 new circuits, 4 20a and 5 15a circuits.
We are installing a new 125a sub panel to feed this area.
The only thing that might be considered unusual is that there are no serviceable stairs that are accessible, so the 2nd floor requires using the fastened in place ladder. The job site has been clean.
I put a little more detail below if anyone want more specifics. We are doing the job on T&M so it's not a problem in that regard, it just seems to be taking a long time. Then again the weather has been way too nice out here in sunny CA to work too hard.
Thanks for any input.
Top Floor:
5 duplex outlets on a 20 amp circuit for the eating area.
22 Incandescent line voltage can lights. These are in three zones. The first two zones are controlled by 3W switches approximately 30' apart and the third zone is controlled by a single pole switch.
3 Fluorescent cans in the bathroom controlled by two separate SP switches.
1 outlet for a vanity light controlled by a SP switch.
1 vent fan controlled by a SP switch.
2 duplex outlets in bathroom.
8 duplex plugs in the living room on one circuit which is a home run.
1 duplex outlet at the rear deck.
2 lighting outlets for the rear deck (either side of the French doors) controlled by a SP switch.
Lower Level:
10 Incandescent line voltage can lights in 2 zones controlled by 2 #W switches approximately 30' apart.
8 duplex outlets in the family room on one circuit.
2 lighting outlets for the rear yard on one SP switch.
1 GFI outlet for the rear yard.
1 20a duplex plug for laundry
2 Fluorescent cans in laundry controlled by 2 3W switches approximately 15' apart.
1 under cabinet light in laundry controlled by SP switch.
3 fluorescent cans in bath controlled by 2 SP switches.
1 lighting outlet for vanity controlled by 1 SP switch.
1 vent fan controlled by 1 SP switch.
1 GFCI outlet in bathroom.
1 furnace circuit.
1 new 125amp sub panel to service the above.
6 lighting outlets
27 duplex outlets
40 can lights
2 vent fans
6 3W switches
furnace (j-box)
Top Floor:
Lower Level:
1 furnace circuit.
