Knuckle Dragger
Master Electrician Electrical Contractor 01752
- Marlborough, Massachusetts USA
- Electrical Contractor
I know this topic must have been covered before at some time.
Back ground on this topic there is a total of 5 combo and 5 smoke alarms already installed in an existing house. I need to add 2 combination, 1 heat and 1 photo smoke to the existing system.
When I asked First Alert the above question they emailed me this, but six additional combination smoke/ co units doesn't sound right.
Do any of you access to NFPA to back up this claim?
What has your experience been with this?
Thank you!
Thank you for your inquiry. According information provided by the National Fire Protection Agency (NFPA), the maximum number of detectors allowed on one residential circuit breaker is 18. However, out of those 18 detectors only 12 can be smoke alarms. So the break down of that would be up to 12 smoke detectors and the other 6 can be a mixture of combination smoke and carbon monoxide units, just carbon monoxide, or a heat detector. Here is a link to our website with an explanation about the information you are seeking as well http://www.brkelectronics.com/faqs/oem/how-many-smoke-alarms-can-be-interconnected. A commercial panel would be required if you were trying to interconnect more than 12 detectors. You can also visit the NFPA website for an in dept break down of this information along with code regulations.
Thank you for contacting first alert.
Thank you!
