zappy said:I heard there's a law that says 10% or $1000.00 which ever is less.Is this true?Thank you for your help.
A common method would $1500 down, $1500 after rough, $1500 after final, and $500 after CO/punchlist. Otherwise, you could use $2000/$2000/$1000.zappy said:So is there a % you use?Say parts and labor is $5000 what would you ask for as a deposit?
tyha said:EC's from NC check me but I think it may be illegal around here to ask for a deposit unless there is certain non returnable equipment or some sort of special condition. I do know for a fact that all the guys that get in trouble and go before the board have a certain part of their sentence stating that they are not to invoice until a certain portion of the work is complete and inspected.
You're right in CA.there is a law 10% or $1000 business & profession code#7159 unless your a big company like home depot.mdshunk said:I wonder how the flat rate guys get along in California? CA does have a rule that you can't get more than 10% down, but most flat rate systems require that the tech has a check in hand before he starts the work. Maybe they just have them sign on the dotted line, instead, then get them to pay immediately after the work is done?
zappy said:You're right in CA.there is a law 10% or $1000 business & profession code#7159 unless your a big company like home depot.
