transman2
- Brooklet,Ga.
I have 14 highbay Lts @2.3amps, 208v each and need to 3-way them. What is the best way to do this. Any help is appreciated. THANKS. :smile:
			transman2 said:can this be done witout a contactor. I will have 2 - 2pole breakers feeding them and seems like I would have to have 2 relay coils doing it that way.
Not unless you like it that way. Lighting contactors are available up to 12 pole normally, and you can get general purpose contactors in 4-pole quite easily. Be advised that a control system is not required to break every hot wire, if you choose to go that route. You can break one hot of each circuit, and use a 2pole contactor.transman2 said:Does this mean I will have to have 2 contacors
mdshunk said:You can break one hot of each circuit, and use a 2pole contactor.
Thanks, Bob, for that quick correction. I've never done it that way, but it seems that 410.54(B) is specific to HID fixtures. Any other type of 2-pole load, and it would be okay. I guess this is a safety issue, related to maintenance and repair.iwire said:Marc he can not do that for the same reason he can not do that with the three ways.
410.54(B) prevents it.
I guess. I use DP stats on baseboard heat, because I've never seen a SP stat with a marked "off" position. Lacking that marking, you need a disco within sight of the heater.iwire said:Marc I would not do it that way either....but on the other hand we often used SP Thermostats with 208 / 240 baseboard heat.
Kind of a personal double standard.:roll: :-?
mdshunk said:I guess. I use DP stats on baseboard heat, because I've never seen a SP stat with a marked "off" position. Lacking that marking, you need a disco within sight of the heater.
See if 424.19 does anything for you.iwire said:What section requires a disconnecting means within sight of a baseboard heater?
424.19(B)(1)iwire said:How about 419.(B)(1)? [sic]
