We have an old Baldor pump motor rated for use in hazardous locations. It has an aluminum junction box on the side for connecting the motor leads. This junction box must have been sold as part of the motor because it has a Baldor nameplate on the cover. But inside the junction box, there is no lug or screw terminal to land an EGC for bonding. Nor is there an EGC wire among the potted leads coming from the motor (into the junction box). I've attached a photo of the open junction box. Note, there's no place to attach an EGC to the junction box cover plate either (not pictured).
I am using rigid metallic conduit to bring the power conductors to the junction box. I know that metallic can be used as the EGC for non-classified locations; not sure about classified. But even if using the conduit alone is permissible, I would prefer a dedicated EGC wire.
Thoughts & recommendations?
