How to calculate kW on split phase panel
Hi all. Quick question, when calculating the kW load on a split phase (120/240V) panel. Do you use 120V or 240V in the calculation for V(V)? P(kW) = PF ? I(A)? V(V) / 1000
So if I measure 15A on one leg and 20A on the other leg feeding a small 120/240V, 100A panelboard, whats the total kW load on the panelboard? Assume 100% pf.
Thanks.
