mathan1987
- Seattle
- Electrical design engineer
How to check the switch board and panel board breakers for the selective coordination setting at field?
Do you want to check it or test it? Checking it would imply that you are looking to make sure that whoever did the selective coordination design documented it somewhere and the settings on that document match what is in the field.How to check the switch board and panel board breakers for the selective coordination setting at field?
That depends on the breaker.older units had dials which you could look at, most probably have a display you need to scroll through, and some require computer software and a communications connection.I wanted to know how to check the time settings on the breakers at site done per the design documents.
