How to connect SER ground in meter main panel that has no space for ground?
gorms
New member
San Jose, CA
I am replacing the cable that runs between my meter combo and the sub panel that powers the whole house. The reason is it’s currently run in a conduit that is in the way of some garage renovations and an SER cable will allow me to route it properly. The conduit is currently the ground connection between both panels. In the meter combo, there is a lug for the neutral and a smaller one for earth ground but no additional lug for feeder ground. The meter combo is likely the age of the house (1968).
This picture shows the two hots and the white neutral coming from the sub panel into this main disconnect. With an SER wire, I will have an extra ground wire that should be connected to neutral since it’s a main. The neutral and ground will be separated at the sub panel.
Sorry about this
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
