I have an European equipment that operate at 400V, 50Hz at a reserch facility. It is a a radio pharmacy equipment called, Cyclotron. A cyclotron is a type of particle accelerator in which charged particles accelerate outwards from the center along a spiral path. Not exactly sure what this equipment consists of, probably a motor??
Now, the building voltage is 480V, 60Hz. Chaging the voltage is easy. I can provide a step down transformer. But how do I change the frequency to 50Hz? Can I simply install a frequency converter along with a step down transformer? Is this a even a good approach?
or Can I use a VFD for this application? The equipment consumes about 600KVA of power. Not even sure a VFD is available (or phase converter fo that matter) for 600KVA rating.
