How to Copy paste from 02 NEC to Forum?
mikeames
Gaithersburg MD
Teacher - Master Electrician - 2023 NEC
How do you copy and past from the 02 NEC on disc to these forums. You can view the NEc as a PDF of in the "Folio View" :roll:
Re: How to Copy paste from 02 NEC to Forum?
Mike I use the folio view just go to the section that you want to copy position your mouse curser at the top left of the text you want and then hold down the left mouse button and drag it accross and down to highlite the text when you get to the last of the test let go of the left mouse button this will leave the text with a black back ground then just click the right mouse button and then select copy in the dropdown list this will copy the text to the clip board now switch back to the forum where you want to post it and when your ready right click the mouse where you want the text and click on paste in the dropdown list and your text will now be in the post. Now this wont work for charts or graftics . and if the text that you want to copy is longer than the window just use the scroll wheel if you have one on your mouse while you still hold down the left mouse button. hope this helps
