How to determine enclosure size?
MateoT
New member
Houston - Texas
I've been searching the code for an appropriate answer...but everything seems to be based on conduit size.
My question is, if I have a jb like the one below, how do I determine the min. size of this box, assume there are no conduits, just cables and their glands
what sections of the code are applicable?
Thanks for your Help!
Regards,
Mateo
Welcome to the Forum!
There is a whole lot of terms in the NEC Index under Junction boxes. Maybe a certain aspect of
the work was not presented in the original OP statement. Make sure that you address the needs
of the environment of the install.
Since your using a cable and showing a power distribution block that is I'll assume is under
1000 Volts, Article 314.28(E), remember that all aspects of (E) - 1 through 5 should be met.
