I need to size a motor starter for a motor with name plate ratings of
Voltage : 380V three phase
Watts: 11K
FLA: 22
No hp rating
I believe it's a German motor. It's for a pump that pumps hydronic fluid for hydronic rollers.
I plan on feeding this motor with 480 V.
There is another one of these exact same motors already running on 480v and it runs fine.
Will the voltage increase change the HP?
This other motor is fed directly from a machine control unit and I'm not even sure if it has OL protection. I can't turn the machine off during business hours to look into control unit.
I need to size this motor starter and throw in a disconnect to the motor.
I plan on feeding it with 30 amp circuit.
Now I need a NEMA size ???? Starter.
Thanks
Watts: 11K
FLA: 22
No hp rating
Thanks
