Is there a way to know how much internal impedance I have based on Harmonic voltage and current? I can measure all harmonics (voltage and current) but do not have access to source data. It is generator.
Thanks,
Trying to calculate source impedance backward only from a known THD value is, I suppose, theoretically possible, but I think would be like trying to push a rope up hill.Is there a way to know how much internal impedance I have based on Harmonic voltage and current? I can measure all harmonics (voltage and current) but do not have access to source data. It is generator.
Thanks,
how is the THD data presented
by fundamental freq and harmonics?
can you show us the data?
if the fund is >90% of the energy/power, I would say a good approximation of |Z| is possible but without time stamped data phase might not be possible
it is a VFD running a 30HP motor at full load fed by a 440V 50Hz 60kVA gen. There is also a a passive harmonic filter upstream to the drive.
THDv=2.3%
THDi= 6.5%
the VFD changes things
now it is non-linear
let me think about it
what are you trying to do?
model the system in a simulation program?
