Joe555
- Pacific NW
- Retired
Hello,
Need a little help here as safety is all our primary concern. I'm trying to develop a dual tracking system that is cost-effective. The Invertors in our test system are transformerless or non-isolated and the PV modules are not grounded except at panel frames and panel support (tracking) frames. Since each panel will move I need a flexible cable and am not clear on NEC code for bonding and splicing using a multistrand cable. Was thinking of using UL-approved WEEB connector washers and crimp lugs with 8 AWG PV Wire but would that violate the permanent splice rule because of so many connections (2 lugs per) which I believe does not apply to EGC? but since there is daily motion is still a concern. What about GEC grounding and the fact that due to motion, steel and aluminum parts conductivity might be an issue and any bonding between parts would still require a flexible cable? I have contacted electrical parts manufacturers but so far no clear answers.
Thank you in advance for your time and any help you can offer,
Joe
Joe
