jbc said:what is the proper way to install a delta ground, using cadweld?
jbc said:how can i make a triangle pattern when i am using cadweld to make my connections?
tkb said:In a triangle pattern.
ptonsparky said:What is the reason for this or where would it be used?
No, it's more like a single 3/0 conductor laid across the top of the rod, in a T shape, and welded on that way.jbc said:cool , so they should make a mold that can handle two 3/0 c.u to a 3/4 ground rod.
