e57
- San Francisco, CA
Spotted this on a welding sight - thought you gents would find it funny.
http://weldingweb.com/showthread.php?t=11537
zbang said:That's "special". Wonder why he couldn't afford a box?
ItsHot said:What is the toothbrush in the first photo for?:-?
The extension cord was just the begining. I read pretty far into the thread and there was some pretty interesting advice being given.
To brush their tooth ofcourse. lolItsHot said:What is the toothbrush in the first photo for?:-?
somebody's house will burn down soon. They are talking about making "custom" extension cords.
12-3 cord, w/30 Amp male plug to plug into their dryer recept, 50 Amp recept on other end to plug their welder into.
iwire said:Certainly some bad advice out there but let's not forget the overcurrent protection rules for welders and the supply conductors are quite different and would likely allow 12 AWG on a 50 amp breaker. (See 630.11 and 630.12)
ultramegabob said:that may be fine and dandy if they hardwire a longer cord onto the welder, but an extension cord could be used by someone to run an aircompressor or some other equipment.
EBFD6 said:12-3 cord, w/30 Amp male plug to plug into their dryer recept, 50 Amp recept on other end to plug their welder into.
If you read it closely, he said he was adding one. He may have done it that way to show how it was made up.zbang said:That's "special". Wonder why he couldn't afford a box?
And that is actually one of the safer ideas these guy's thought up.
DanZ said:Do you know how hard it is to find a 8 AWG extension cord?!?:roll: That is, if their welder is 50A. Then again, from what I've read on dryers, you can only use an extension cord if it specifically made (and UL labeled) for that use. Which means you're supposed to buy a longer hardwired cord if you need a longer cord. So, they're not only setting up a fire hazard, they just voided their warranty!:grin:
I get the feeling you wouldn't want to see if they tried installing a breaker and permanently wiring an outlet for their welder!
e57 said:Spotted this on a welding sight - thought you gents would find it funny.
DanZ said:Do you know how hard it is to find a 8 AWG extension cord?!?:roll: ....
iwire said:Now we get into the what ifs. :smile:
How is that different then this?
16 AWG cord with three 15 amp receptacles at the end, if I use it improperly it will be overloaded.
