I am going to size a motor protection circuit breaker (MPCB) based on the NEC article 430 and what Mr. holt have said in ?5 motor calculations? video tutorial which is available in YouTube, but I have a problem in matching NEC rules with reality. For example for a 400V, 3 phase 4KW induction motor, SIEMENS suggests a MPCB with 10A rated current, 7 to 10A adjustable thermal overload current, and 130A as instantaneous short circuit or ground fault protection which is 13 times of the rated current of the MPCB. 130A for short circuit and ground fault protection is greater than the one given by NEC. So you are kindly requested to give me a description about this issue, if possible. Could you give an example for sizing and selection of a MPCB based on NEC rules, considering that short circuit protection of most MPCBs is fixed and in the order of 13 times of their rated current?
