JEFF MILLAR
How to include Excel file attachment in support of question. Is there a special type of file extension. required ?
Tell me that’s a really old sheet. Those labor rates seem way lowThis ?
LABOUR Hours Rate Senior Engineer Normal time 40 £48,50 £1.940Time and a half 0 £72,75 £0Double time 0 £97,00 £0Total 40 £1.940 £1.940
It's just an example and the currency is British Sterling.Tell me that’s a really old sheet. Those labor rates seem way low
British Pounds are worth about $1.13 USD.It's just an example and the currency is British Sterling.
Yes but I was but I was just to see if I could help the the original poster. Not currency rares.British Pounds are worth about $1.13 USD.
Used to be the British Pound was worth almost 1/4 ounce of gold.
Posting attachments like Excel and Word files can harbor worms and viruses. People should NEVER open such an attachment from any website. PDF files are much more secure, I’ve never heard of them acting as vectors for executables. So by converting your spreadsheet to a .pdf, you are making it safe for viewing.
I agree that is the best.... The changing over as I stated may be confusing to some.I'd recommend uploading it to a service such as Google Docs, and making it public. Then you can share it with nearly the same functionality it would have in its Excel form.
changing the extension is a requirement to break a password protected sheet
How hard is it to change an extension? I change them all the time and change them back as you suggested.
Isn't that what I did at post 3 ?You cannot attach an excel file but save the file as an excel then manually change the extension to pdf. Then let everyone know to use the spreadsheet they will have to change the file ext back to whatever it was-- xls or xlsx whatever it was
Ah, OK.No-- all you did was copy the spreadsheet. I am talking about saving the spreadsheet so you can have a working copy in excel. Suppose you had a spreadsheet that did the standard calculations, optional calc etc. You need to be able to plug in your own numbers and see what the load would be.
