Muhammad Umer ansar
- karachi pakisatan
- junior electrical engineer
I came accross the following tasks during my trainee period in an electrical firm. I was provided motor with no nameplate in following conditions:
1) When I can remove the mechanical load from the motor, so that i can run it on no load.
2) When i cant remove the mechanical load from the motor shaft. That is, i need to predict the Motor KW and current rating at loaded condition.
3) When the motor is defective, that is it is not starting( or i cant start it for some reason like overcurrent etc)
My questions are:
1) How to predict(calculate) the KW rating and current rating of motor in above three conditions?
2) If in any case i am unable to predict current rating then how do i know what size of Breaker and protection do i need for safe testing of that motor ?
3) Can i calculate the KW rating using physical size and parameters of a motor?
Umer.
My questions are:
Umer.
