duttonbrown
Lighting Designer
- Minneapolis, MN, USA
- Product Engineer, Lighting Designer
Hello,
I have a lighting design shop in an older space with one 20A supply for the space. We test fixtures to repair them, and on occasion, we trip a breaker when there is an unforeseen loose wire.
Is there any sort of device that can be used between a wall outlet and the plug for the product we are testing that will trip at a lower amperage so that I can avoid needing to contact maintenance to flip the breakers?
We were told previously to install GFCI's, which we did, and those have tripped a couple of times but not every time. What is the appropriate device to use? Or do we need to have a new line run down to our testing area with its own breaker?
Thank you so much for any help.
