Is that an opposite situation (of the OP heater situation) where current and voltage are inversely proportional (or at least of a way different relationship than in a purely resistive situation), i.e., raising the transmission line voltage delivers the same power at the destination--but with less current flow (per watt delivered) than otherwise would be the case on the transmission lines.   ????    In any case, I am wondering...everything else being the same, or constant, what generally would be the change in current magnitude on transmission lines if voltage is increased ?    If transformers at the destination present a largely inductive load, on long distance transmission lines, what can be said about the relationship of voltage to current on such lines ?
Current is less proportional (but still nevertheless proportional?) to voltage than is the case in resistive loads?
