Hello everyone. I am new here. I am making an audio amplifier with TDA7297 15W+15W. I take the input from the jack 3.5mm and I also input from the SD card module (it can decode the data into audio signals already, it is called DFplayer mini ). I want there is a switch and when I switch it takes the input from the jack 3.5mm and switches off the SD card module, and when I switch to the SD card mode, it switches on and then plays when I hit the buttons or something. Is that possible? My background isn't so good, I'm a newbie so hope you guys can help me to figure this out. Thank you so much
