In a building with prestressed concrete, I want to use unistrut channel and all threaded rod to support conduit and cable tray. But the structure engineer said they will use prestressed concrete, and I can't drill on the floor or wall. They will bury steel plate into the floor, and the hanger will be sealed to the steel plate.
I want to know, under this condition,
1, Can I drill on the floor or wall?
2, Can the unistrut system be used, how to connect it to the structure of the building? By seal, beam clamp, or anchorage? I'm wonder if there exist beam in this type of building.
3, If the steel plate will be buried, we have to make sure where to place the hangers at the first stage. If we change the place, how to connect it to the structure?
