D&Lelectric
New member
i am having a problem with the inspectors here,they say they have a true arc fault tester and i am now falling my inspections i need help
Welcome to the Forum, D&L!i am having a problem with the inspectors here,they say they have a true arc fault tester and i am now falling my inspections i need help
OUTLET CIRCUIT TESTERS (QCYU)AFCI indicators operate by producing a waveform similar to an arc fault. Since these devices cannot produce an actual arc fault, an AFCI indicator may not trip every AFCI. AFCI indicators are provided with markings or instructions that state the following or equivalent: ??CAUTION: AFCIs recognize characteristics unique to arcing, and AFCI indicators produce characteristics that mimic some forms of arcing. Therefore the indicator may provide a false indication that the AFCI is not functioning properly. If this occurs, recheck the operation of the AFCI using the test and reset buttons. The AFCI button test function will demonstrate proper operation.?? These devices are not intended for use as comprehensive diagnostic instruments.
GENERAL
This category covers portable devices with fixed attachment plug blades, or probes attached to flexible leads, used to indicate various wiring conditions in 15 or 20 A branch circuits by a pattern of lights or other similar means along with markings or instructions to identify the probable wiring conditions which cannot be determined by the tester.
The devices may include provisions for checking the functions of a ground-fault circuit interrupter (GFCI) connected to the branch circuit, or for indicating that a branch circuit is connected to an arc-fault circuit interrupter (AFCI).
I have moved these posts to their own thread from the "AFCI myth" thread to keep that thread from being hijacked.
By the way welcome to the forum.
Chris
I use a gfci, afci tester that sometimes trips the afci, but not always.i am having a problem with the inspectors here,they say they have a true arc fault tester and i am now falling my inspections i need help
If it doesn't, I press the button on the breaker.
Chris
