How to test double pole 240v 30amp GFCI breaker for correct GFCI functionality
mcline
New member
seattle
Hi
I installed a double pole 240v 30amp GFCI breaker for a 3 wire pool heater with the breaker's white piggy tail connected to box neutral, load ground to box's ground and the breaker's load neutral disconnected. I wired the breaker to a L6-30 outlet.
Before using it in the pool heater, I would like to test the outlet for GFCI functionality. I have not been able to find a 240v gcfi tester. All of them are for 120v circuits. It's incredible.
How can I test it to make sure I wired it correctly and everything works as planned?
Thanks
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
