Hello.
I have a Dyn transformer serving a single phase resistive load(with the other 2 phases on the secondary open).The turns ratio of the transformer is 1.
How can I use symmetrical component method to calculate the primary line current?
The current in the secondary winding is 5A.I have used the symmetrical component method to work out that two of the coils in primary will not conduct any current.How ever from my calculation the current flowing in the only coil in the primary is also 5A,which is not consistant with the data I get from experimet(2.9A)
Could someone point out which on step I may make a mistake?
