scwirenut
- Sumter, South Carolina
I have 5 quadplexes (20 units) and 11 duplexes to upgrade from 100amp to 200amp, also add a range circuit. the problem is SPACE. I have to use a loadcenter because the new range must be fed from outside. If I use 2gang/4gang meter bases with 8cir MB loadcenters under ea, then I cant access each of the old feeders (they go on a 100amp breaker) the new panels are 22" wide, also it would be difficult to leave each loadcenter with the range up through the soffit above (slab)
I first thought of putting the meters below but the POCO requires a min. of 3' high.
Im highly considering installing 4 individual meter main combos side by side, by getting the lateral out of the way I think I can offset each combo to fit, then build a trough under it for the lateral. then slap a hub on top and we are off to the races. opinions please...
