busman
- Northern Virginia
- Master Electrician / Electrical Engineer
Needing to add a subpanel adjacent to a main panel due to over-crowding and need to add new circuits. In order to make space for the 2-pole (this is residential) CB in the main panel, two circuits need to move to the subpanel. I see two options, wondering which you would do and why.
1) Pull a couple Romex out the top of the main and move them over to the adjacent subpanel (if they are long enough). Seems like more work, but maybe neater.
2) Wirenut some extensions to the hots and neutrals in the main and run thru the same nipple that connects the main to the sub for the subpanel feeders. Probably not as neat looking (but not normally in view). Also, some slight chance in more crowded panels of not grabbing the correct neutral that correlates to the hot and causing induction heating.
I'm leaning toward the latter being faster.
Thoughts if you will please.
Thanks,
Mark
Thanks,
Mark
