bjp_ne_elec
- Southern NH
Need a WP Disconnect for a small A/C unit that is 240V/20A. Obviously it's on an outside wall and the wall is going to be finished.
Running NMB from panel to wall, and then what I'm struggling with is how I make the penetration to the outside and terminate in the disconnect. I know you can't run Romex NMB to the outside - so what would you do - put it in a PVC nipple. If it was exposed inside, I would run EMT with an LB to get through wall in to the disconnect - but everything needs to be concealed behind the sheetrock.
Keep in mind my experience is heavy commercial in my past life, so I probably ask a lot of stupid questions as I work to learn more about the differences in residential, and light commercial.
Thanks
Brett
Thanks
Brett
