Can you not just pull the wire out of one end and replace the lb. It looks like the LB is at the base of a 90 degree elbow. It would be hard to flush mount.
Is that conduit going up into the concrete into the bottom of a panel?
I'd cut that conduit off flush with the concrete, then extend that underground conduit so it's tight to the wall. Run the pvc up against the wall and LB through into whatever it's feeding. I can't think of anything else that'd look very clean. You could cut that broken LB out and install a chunk of pvc flex in it's place possibly if there were no worries about physical damage.
Can you drill through the concrete of the building on an angle? If so, I'd think about drilling to a point below grade and "hot bend" as as suggested, then make up the pipe under ground.
