travish
- Central North Carolina
- Electrician
We are building a resistance welding machine here at work, It has 3 welding transformers that are each on casters so they roll to change for different product widths. My question is specifically from the cabinet to the welder. There is no means for grounding the transformers inside the x-formers. I ran liquidtite from the panel to each x-former with only the phase conductors inside, because there is only 2 lugs inside the x-former.
can I run one ground wire from the cabinet to the frame of the machine and then ground each x-former to the frame of the machine, or do I need to run 3 ground wires and land each on the corresponding welder frame?
Thanks
Travis
Thanks
Travis
