How would you wire a SABC?
So for my kitchen CounterTops, I'm running a separate 20 amp AFCI/GFCI, but for my other counters along the walls, I would like to run two more 20amp circuits also coming from two more AFCI/GFCI Breakers. Can I do this by tying these two breakers together and running 12-2-2 Romex and splitting the outlets top and bottom, running the red/white-red to the bottom and running black/white-black to the bottom?
This is my first post here, by trade I'm a Maintenance Supervisor. Maintenace people are the ones that normally cause all the grief for the electricians out there, I can admit that. :)
I'm rebuilding, replumbling and rewiring my enitre home with permits. I might be doing a little overkill on almost thing I've done. Because maintenace is what I do, I things I have to fix have been those items that were valued engineered, or some crap a great salesman has sold somebody. So I'm changing from a old (4)screw in fuse electrical system to a new Seimens panel that I'm running separate AFCI/GFCI 20 amp circuts to almost everything. I know, overkill! Oh yeah, I read nec 2014/2017 and read as many books and videos possible.
I know many of you are required to do the job as bidded and know that the cheapest bid gets the work. This is my home and and I really want to do this once and not have problems that I see with building to code minumums.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
