I am having a problem with a Hunt Electronics dimming system from (around 1975). I have a bad dimmer 4 wire part # ifc-1. And have a bad card in a dimming module. Dimming module # is id-20. Anyone ever work with this stuff. The One dimmer was loose so when they turned it a wire broke off, I can solder this back on. A handyman changed the other dimmer to a single pole switch. After a few days thge lights only illuminate half brightness. I did some looking around and was only getting 50 volts at the light, when i switched the card from a known working, lights ok. Any idea where i can locate these parts? Thanks in advance
This house is wired pretty weird.The rest of the lights that aren't on the dimming module , are run through relays with low voltage switching.Hope some one can help
