hardworker
What awg size supply conductor would you recommend for an airhandler w/heat element that has minimum circuit ampacity of 84, maximum breaker ampacity of 60+60, and the supply run is 50 ft. Also what awg for the ground?
What awg size supply conductor would you recommend for the heat pump condenser that has minimum circuit ampacity of 24.6 maximum breaker ampacity of 40, and the supply run is 60 ft. Also what awg for the ground?
