HVAC Equipment
geochurchi
Concord,NH
Retired electrician
Hi All, is there a code requirement that prevents HVAC equipment i.e. boiler from being connected with a cord and cap?
Thanks :?
From an NEC point of view, a cord is a substitute for a permanent wiring method, and HVAC equipment does not require frequent exchange, therefore cords are prohibited. I happen to agree with this position.
It would be OK if the manufacturer sold it with the cord set attached.
I will try and do some research for documentation, but that is my memory also. The UL listing prohibits cord and plug unless the manufacturer allows it and supplies it. We got really deep into that a few years back on a gas air handler.
Here is info from one file:
Question:
Has UL Listed any cord-and-plug connected central air-conditioning units, central heating furnaces or storage tank water heaters?
Answer
No, UL has not Listed cord-and-plug connected central air-conditioning equipment or central heating furnaces.
These types of equipment have been Listed for permanent wiring installations only. They are Listed under UL product category Heating and Cooling Equipment (LZFE), located on page 223 in the 2010 UL White Book or may be found on UL’s Online Certification Directory at
www.ul.com/database by entering the category code at the category code search field.
Only small capacity (5 gallons or less) electric household storage tank water heaters or electric commercial water heaters that are designed to permit removal for maintenance and repair have been Listed for cord-and-plug connection. These products are Listed under the product categories Household Water Heaters (KSDT) and Commercial Storage Tank and Booster Water Heaters (KSBZ), both located on page 220 in the 2010 UL White Book, or may be found on UL’s Online Certification Directory at
www.ul.com/database and entering the category code at the category code search field.
The requirements used to investigate these products are detailed in the Standard for Safety for Household Electric Storage Tank Water Heaters, UL 174 and in the Standard for Safety for Electric Booster and Commercial Storage Tank Water Heaters, UL 1453.
Tags:
water heater
Category:
UL Question Corner
HVAC equipment
HVAC equipment
OK Thanks, just wanted to be sure,didn't think of the permanent cord restriction.
Geo
