vasparky27
- Chesapeake, Va.
scenario:
10 KW heat strips in furnace with 3 ton heat pump
Do I need to use 90 amps feeding a sub panel?
60 for the strips and 30 for the heat pump?
Why I am i wiring them on such a big load size if they are never going to be running at the same time? couldent I just feed the panel wITH 60 AMPS?
