mike30jr
New member
- thomasville, GA
I am currently bidding a job that requires feeding thirty seven mini split ac units out of two panels. I was looking for the load calculator for hvac equipment, and found that it usually calls for you to figure hvac equipment at 100%. I was just woundering if this is the case for a total hvac fed panel. This seems to be a huge load, and wanted to make sure that this is right?
