DAC8
- United States
I've been noticing lately, in commercial buildings specifically, HVAC contractors have been changing large RTU's with electric heat to gas units that draw a much smaller load. What doesn't sit right with me, is that, the breakers from the old units are left in place and a fuseable disconnect and fuses are installed to accommodate the max fuse rating on the nameplate, to cut cost I'm sure. Example: 200 amp breaker at the gear, 60 amp disconnect with 60 amp fuses. I'm familiar with article 440.22 but it does not specify, weather or not, the 225% is for the entire circuit. Could you please clarify?
