HVAC wire sizing question
Washington
Electrician 01
I have RTU that has a rating of 52 amps with an MCA of 52 amps. Going by the code it looks like I can use #6 thhn dual rated because the 75 degree rating is 65 amps and for a continuous load of 52 amps it meets the 80% correction factor. Is there something I am missing or does this work out just perfectly?
Sorry the MCA is 65 amps
You'll need a conductor with a minimum ampacity of 65 amps. What is the wiring method? If it's conduit and wire or MC cable you can use #6 which has a 75° C rating of 65 amps. NM cable (60° C) would require #4 AWG conductors.
What do you mean by the 80% correction factor?
The 65 amps mca has already calculated the 125% factor for the a/c unit. 52 amps x 1.25 = 65 amps. If the unit states 52 amps mca then you do not multiply by 125%. I am assuming the mca stated on the unit is 65 amps so your wire should match that based on either 60C or 75C depending on your wiring method.
What is the MOCP listed on the nameplate on the unit?
