I have some quetions that are on my pre test study guide that I need some brushing up.. The first question is A 240 volt 2 horse power , single phase AC motor requires a branch circuit capable of carrying a minimum of A. 30 amps B. 25 amps C. 20 amps D. 15 amps The nxt question is The minimum neutral demand on an apartment service for 11 8kw ranges would be.... A 88kw B 32kw C 20.8 kw D 18.2 kw the next question is For the purpose of computing neutral demand, a 15 kw range would add A 15kw B 9.2kw C 7.36kw D 6.44 kw The next questin is A 230 volt 1 horse power singl phase AC motor is connected to a branch circuit supplied by #14 THW conductors. The MAXIMUM inverse time delay breaker permitted to protect this circuit would be a A20 amp breaker B 25 amp breaker C 30 amp breaker D 40 amp breaker. The next question is a 230 volt 1 horse power single phase AC motor is connected to a branch circuit supplied by #14 THW conductors. The overload protection for this circuit would be a A 11.5 amps B 12.5 amps C 15.0 amps D 20.0 amps The next question is a 100' run of rigid nonmetallic conduit is installed on a day when the temprature is 700 F. If the temprature increases to 1000 , this conduit would be expected to increase how many inches in length? A o.25 B 1.22 C 1.42 D 2.31 If anyone can please take the time to give me the answers and explain how the answer is found or the steps it will be VERY appreciated..... I have taken electrical classes in the past but it has been awhile since then.... Thanks
