gilamor
- Santa monica CA
My name is Gil
I am an electrical contractor c-10 located in Venice CA
Recently I had few jobs where I had to trace wires find junction boxes etc
I have the 200 IntelliToneProus but this nice toy doesn’t work on line voltage.
So I am looking to buy a wire tracer for high voltage. After couple of day of research
I came up with these 3 testers below. The speck and fetchers are almost the same.
The price is about Amprobe=$461 greenlee=$539 and ideal=$599
The greenlee looks like an old instrument that was never upgraded I also read some bad comments about it in this forum. But greenlee is a good name in the electrical business
I wondered if anyone had any experiences with these testers.
Reliability? Ease to use? And if they really works as stated ?
Thank you very much
Gil Amor
Ideal SureTest Open/Closed Circuit Tracers
• Numeric value and audible signal provide quick and easy-to-understand tracing feedback
• Receiver display rotates automatically for easy viewing
• Identifies breakers and fuses
• Pinpoints opens and shorts
• Traces wires behind walls and under ground
• Can be used on circuits 0-600V AC/DC
Greenlee 2011 Power Finder Circuit Seeker Microprocessor-Based Circuit
•Traces concealed wiring, locates junction boxes, and finds breakers for live or dead circuits?no need for power interruption.
•Finds breaks in wires and shorts to ground.
•Incorporates auto gain circuitry for enhanced accuracy.
•Locates and identifies blown fuses.
•Supports transmitter-to-receiver distances up to 4 miles (6.5 km) for closed circuit tracing.
•Accessories included: Adapter lead, (2) 9V batteries, AC blades, instruction video, extension leads, carrying case, earphone/tube.
Amprobe AT-4001 Advanced Wire Tracer
• One universal transmitter- automatically switches to work with either energized or non-energized systems .
• Receiver not position sensitive- does not need to be rotated in order to provide accurate readings .
• Locates and traces wires in walls, floors, conduit, computer cables and other hidden areas.
• Traces energized and non-energized (open, broken) wires
• Does not interfere with sensitive electronic equipment.
• Pinpoints shorts, ground faults and broken wires.
• Performs tests without having to interrupt power .
• Traces live wires buried or hidden behind walls.
• Locates breakers, neutrals, and ground lines.
• Extremely easy to use.
Edit; removed email addresses
Thank you very much
Gil Amor
