- Windsor, CO NEC: 2017
- Service Manager
A spinoff of "I am the NRA."
There were a couple decent calls: exposed lamps in the cans in the master closet, good catch. A couple of exterior fixtures were undeniably saggy.
There was a questionable call: The brackets that supported the fixtures outside (and by reputation, the bathroom too - I didn't get that far) were not grounded. The fixtures themselves were grounded, but the bracket wasn't. In addition, the brackets were installed in pancake boxes (Allied 3.5 cu. in.) attached through the pancake into the OSB behind by sheetrock screws.
I readily admit, that was cheesy. But I don't believe a violation existed. I called the AHJ and left a message, and the GC wanted an update, so I let him know. (He's actually a former employee of my company, but that's neither here nor there.)
When my call was (to my shock) returned, I admitted outright that I thought the installation was cheesy, but went on to explain that I saw no violation, and could he please cite a reference.
He said he didn't have the code memorized, but that the bracket had to be grounded. I told him it was, the nuts have to cinched down in order to get the fixture to seal tight against the wall, effectively grounding the nuts and screws. I then hit him with this:
To which, I replied, "But this section seems to disagree with that. Take a keyless for example..."
He interrupted, "But if the hot is scarred, and comes into contact with that bracket when the fixture is down, then it will be hot."
(I wish I had said, Why are you taking down hot fixtures?
So, who's right? People more familiar with the code might be able to support him. Rest assured, I am going to find out who trimmed it and put a foot in their fanny, but I stand by it as being compliant.
Thoughts?
To which, he replied, "But it has to be grounded."410.18(A) Exposed Conductive Parts. Exposed metal parts shall be grounded or insulated from ground and other conducting surfaces or be inaccessible to unqualified personnel. Lamp tie wires, mounting screws, clips, and decorative bands on glass spaced at least 38 mm (1 1/2 in.) from lamp terminals shall not be required to be grounded.
Thoughts?
