Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
From the drawing they're clearly feeding a dining receptacle from the laundry room. It also clearly shown the washer and dryer receptacles..Of 210.52(b) 1 and 2.
The SABC that must supply the receptacles in the dining room should not also supply a general use receptacle in the laundry area.
Ckt 9 shows "Rec-Dining" on the panel schedule. My opinion its a no-go.Is this commercial or res? Condo?
What does P1 ckt 9 say on the panel schedule? Sa or general? Is ckt 9 anywhere else? Circuit layout screw ups always seem to clear up via the panel schedule- which trumps the homerun layout imo.
That's certainly not required, but I guess it is allowed. 210.8(F) says "(F) Laundry Areas. In dwelling units, at least one receptacle outlet shall be installed in areas designated for the installation of laundry equipment."General-use receptacles in the laundry room/area should be on the laundry circuit(s).
Once you've designated one receptacle outlet for laundry equipment, you've satisfied 210.8(F), but you can designate other receptacle outlets for laundry equipment if you want. As well as have receptacle outlets not so designated, which would be prohibited from being on the laundry circuit by 210.11(C)(2).
Cheers, Wayne
A bathroom receptacle cannot be on with another non-bathroom. More than one bathroom can share a receptacle circuit but it must serve only the bathroom(s). You can also have a single circuit for an entire bathroom.210.52(F)? I think you misyped 210.8(F).
And you could make it a switched receptacle which is acceptable in the dining area (exception 1).
I guess that leads me to another question, could you use the bathroom receptacle circuit and put it on a switch for the dining room? The exception says general purpose. Does the bathroom receptacle count? It doesn't say that nothing else can be on the bathroom circuit.
Yes, thank you.210.52(F)? I think you mistyped 210.8(F).
What exception? I see no exceptions to 210.11(C)(2).And you could make it a switched receptacle which is acceptable in the dining area (exception 1).
OK, agreed that if the circuit supplies only a non-laundry receptacle and a switched receptacle in the dining room, that's fine for a general purpose circuit, which could be a 15A circuit.210.52(B)(1) Exception 1 -- The image is from the NEC 2020 Handbook
It's interesting because that section states "as required in 210.70(A)(1)". Since there is a ceiling light that switch receptacle is not required.210.52(B)(1) Exception 1 -- The image is from the NEC 2020 Handbook
I don't think that was intended to be a switched recep. I think the Archi just screwed up.
