hi all,
yesterday i took apart 7 different surge outlet strips. all under $25(maybe this is the problem?).
all different models, all diferent manufacturers.
what i found:
all of them tie ground to neutral. this is the entire principle on which they work. i always thought we do not tie ground to neutral past the service entrance in residential wiring? this was my main area of concern on these.
second: soldering on all of them must have been done by a monkey. the connections (all but one) are solid. but, way too much flux and way too hot of a solder. obviously they had speed of assembly in mind here.
third: two of them use backstab recepts as the outlets! the ones that are rated #12 AND #14 even!
of these, one of them has the ground completely unconnected on the recepts, as the neutral now carries the full ground potential.
fourth: 3 of them do not incorporate a thermal fuse. so when the mov's overheat, at some point there could be potential melting of the housing and subsequent ignition of surrounding materials.
mov's can and do reach over 300f. at their limit.
i am not trying to be a wise guy here. i cannot understand how these can protect expensive connected equipment. i'd think they are more likely to destroy the equipment!
please explain what i am not understanding here. there has got to be some reason these are safe that i am overlooking, right?
i am not naming any brands here so no one gets upset. i think the real problem may be the price point of the units i examined. but still, how does ul pass these? fyi: none of them are older than 1999.
thank you,
ron g.
what i found:
thank you,
ron g.
