We are working in an Industrial Facility with two 4000A, 480/277V services. A branch feeds a 400A, 480/277V, QMB Load center. 5 60A buckets with 45A fuses' feed (5)five, single phase, 37.5 KVA, sola CVS x-fmrs. The x-fmrs are feeding some test equipment in their QC dept.
The x-fmr's are located inside the facility above the top of the QC room. The QMB load center is located on ground level just the otherside of a concrete block wall from the x-fmrs.
The top of the QC room is used as a storage area for alot of stuff including one large air handler. There are hand rails around it's perimiter. This area is accesible by ladder or sissor lift only (no permnant stairs or ladder).
From anywhere atop the QC room It is not possible to see the QMB load center. It is located on the other side of a concrete block wall.
My Question is this:
Don't each of these transformers require their own disconnects within sight?
I have looked under Tranfomers, Disconnecting means, Services etc... I'm not getting anywhere fast.
Thanks simon
Thanks simon
